Kubota project #3
MNGB
With 1 & 2 projects completed it on to number 3, installing a rear work light, Kubota was nice enough to provide a wire under the RR fender taped of with blue tape, check it for power it has power with the key switch on. I'm going to run a wire into the cab install a switch so I can turn it off if I want, found a place to mount the light.
Went in this afternoon thinking I could get that light installed, BUT NO for the life of me I could not find a light switch after 20+ minutes I finely found the box of switch's. Got it wired up to the actual LED wires and then it was time to go home. Monday it should be completed, I did test it and it does light up with the switch and its off with the light switch off
