I’ve had a really nice Craftsman jobsite TS Carol bought me over 20 years ago. It wasn’t something I would have bought especially at $450. back then but I didn’t want to hurt her feelings by returning it. It’s been very reliable, still runs well, accurate, and even has a lot of miles on it traveling to the job sites. I’m going to retire it and give it to my son.
The NTM saw I bought a little over two years ago from a guy on Market Place for $150. He had a nice little shop and wanted to downsize to a portable Ridgid TS. Even though it runs very well and works like it should I flipped this upside down to get to the mechanics to check things out. It’s very clean with a little surface rust on the inside of the stand. I done a little cleaning and lubricated the gears. I have a matching cast iron 8” side table with it that has never been used. It also came with a 32” right side table. I have several blade inserts, almost new Freud blade, and a new web belt.
I removed the old saw and cabinet along with the frame it sit on. I have to notch my out feed work table so the motor passes under and rotates as I tilt the saw blade.
I had two choices to raise the saw around 3” or drop my table about the same. Because the work table has had wheels and I never used them I chose to remove the wheels drop the table and pad it to be even with the saw table.
I set the saw up with the long side table for awhile to see how I like it. So far I’ve adapted to it real well.
It has a lot of space under it so my plan is to put a cabinet under there with a couple of slide out panels to hang blades, inserts, etc. on it with mane a drawer or two. Right now I just need it functional the cabinet can wait.
